The latest progress report from Naim;
As promised, an update on the forthcoming Uniti software release, which will enable a range of new functionality, including AirPlay 2 across the range; the ability to turn off system displays; plus support for the optional DAB/FM radio module for Uniti Star and Nova.
The continuing beta test of this complex software update has revealed a few remaining bugs that require fixing, before the update goes for final sound-quality testing ahead of release…
Thank you for your continued patience while we work to deliver the very best possible software update; we will update you further on Friday 3rd May.
Latest update from Naim; beta testing has gone well so far. If all remains well then hopeful for a release announcement sometime next week once we have returned from the High End show in Munich.
We appreciate your ongoing patience while we work to deliver an update that not just adds functionality but meets our stringent sound-quality standards. Significant progress has been made, but we predict it will take another few weeks to complete this major upgrade. We’ll come back to you at the end of the month with an update on the situation.
Airplay 2 for the new Uniti range has been released today. Details can be read here:
https://community.naimaudio.com/t/airplay-2-and-more-arrive-on-the-uniti-range/2466
