Has anyone else had an issue with Qobuz where you start playing an album and when you go to switch to another album nothing is there? Server works fine, iradio works fine it’s just Qobuz.
It works if I stream it from the App just not the Naim app
It does the same thing on my Muso QB2
Unplugged from the EE8 and plugged straight into the modem/router and it worked at first but now more of the same.
Qobuz presets work but only after a 30 second lag
The plot thickens. If I unfavorite an album then re-favorite it then the tracks come back and are available to play
