Kitchen Hifi Positioning Dilemma
Hey folks,
Talk about an awkward kitchen space! :grimacing:
I need to get some Naim in there asap. I’m thinking about an Atom as one possible solution - but the problem is where to position small speakers…
I will listen to music whilst preparing food in the kitchen but also when relaxing on the sofa at the end of the room. The sofa has to stay in the same position, it can’t be turned around.
The priority in terms of SQ is at the sofa end - I can accept a compromise at the kitchen end. However, if I have two speakers literally pointing towards the sofa end, the compromise in the kitchen may be too much.
I’ve considered an all in one such as a Muso but it would take up too much space on the worktop and I can’t see another place to position it. Hence the suggestion of atom plus small speakers.
I’m genuinely perplexed. Any ideas would be very gratefully received…
Hmmm! That’s not an easy space to deal with. To get speakers properly positioned for the sofa they would have to be positioned in the middle of the floor behind the chairs, which seems somewhat impractical. So given that whatever you use is going to be a compromise, maybe mounting speakers under the ceiling, or even in the ceiling, would be the best option. Possibly wall mounted, but the wall to the L of the photo is hidden from view so hard to say whether there is space available there.
What is to the top left in that photo?
From a different viewpoint:
Note, the armchairs are missing on this image.
Wall mounted speakers might work: one above and to the L of the sink, and one above the radiator on the opposite wall. Either that or ceiling speakers. Cabling might be tricky - I would be thinking about concealing them in the ceiling, maybe installed under the floorboards above. This is the sort of install a CI 102 might be well suited to, or maybe an Atom.
I was thinking that side wall but I see it narrows there and is the walkway through to the door.
I can’t any position that is going to give the best sound from a conventional Naim system I think I’d be looking at a Muso or similar.
someone on the forum has a pair of Neat Iotas in their kitchen mounted to the ceiling I think. if I come across the picture, will link it here
Hi Stavrose,
If you can believe this - that is very similar to the layout of our kitchen!
I tried all kinds of bigger HiFi in our kitchen when we first moved in. None were good because of the multiple flat surface reflections.
In the end the best solution was a Naim Qb positioned exactly close to the wall on the worktop where the bend of L shape of the worktop is. I.e between the exterior glazed door to the left and the window over the sink to the right.
Our kitchen is similar and I joked with my wife about where the speakers and systems would go, I didn’t broach the subject twice. Fortunately the main listening room does join the kitchen and has a door, so just let the music pipe through, or depending on the music the door gets shut. Good luck!
A Qb on the worktop as suggested would likely be a good solution. Or if there is space for a narrow low table beside the sofa (to the lhs of the patio doors) maybe a Mu-so 2 would fit there ?
Neat Iota Alphas under the peninsular on the floor? Wide range of colour options on the new ones, but obviously sacrilegious on this type of forum that any speaker is probably going to detract from the lovely aesthetics you have going on.
I installed two pairs of B&W ceiling speakers and two Sonos Amps, Naim Atom would be even nicer. Probably not an option for you though unless you’re prepared to cut through your ceiling plasterboard which can all be made good of course. With the amps in a kitchen cabinet it does make a very neat attangement.
Is there room depth wise for a muso, maybe the new stylish utopia, on a nice coffee table aka HH under the peninsula that looks designed as a breakfast bar.:nerd_face:
I thought a QB on the worktop was pretty much mandatory for any Naim-loving household. That’s certainly what provides the music in our kitchen.
Roger
If me, I would cut that part, place one speaker here , the other one near the radiator.
Is that your house now? If so, where is the kitchen clutter, the tub of spatulas, the knives, the salt and pepper, the bread bin, the compost bin? If only ours could be as tidy!
What you need is a Qb2. The worktop to the left of the sink would be perfect. I really wouldn’t get into running wires for separate speakers.
:grin:
I’m not sure about SQ but if you used wireless speakers (KEF?) then you could perhaps hide the source/amp away and move/swivel the speakers depending on where you were listening from.
Long shot, but it is a tricky space in terms of positioning, flexibility and aesthetics.
Good luck, do post a pic of your chosen outcome :slightly_smiling_face:
Tony
I have a similar enough looking kitchen, and have a Muso roughly where your L is firing into the seating area. Still trying to get a normal pair of speakers in, definitely would be wall mounted.
