For you? Yeah, why not?
Too much coinage for me.
Actually…telling you the truth,when I play music around 10.5-11 volume it sound good ,but 9-10 volume sound dull and boring for me…but than I have problems with my neighbours
With Kudos 808 in your room, I feel you will often see the police guys.
Speakers can behave differently with low volume ,and it’s doesn’t connecting to size of the speaker
Yes, but if you run the 808 at normal volume, they will induce more bass and high frequencies vs the SL2. And I really doubt they will work in your room, or perhaps with a lot of room acoustics treatment.
Roost, normally I would agree but the 808 defies logic somehow…
What you’re saying it’s better in my room …I wouldn’t need much volume
Sl2 can be great as active 2x500
Do you say that Kudos 808 with 500 dr , at normal volume ( to appreciate rock for instance), would work without issues in a 18 m2 room, non treated ?
Mine work in a 22m* untreated room. 808’s are much less fussy about placement than you would think.
French, my room is maybe 5.5m x 4.5m (best guess) I can listen at 7pm on the dial and they sound fine. They really wake up at about 8-8.30. 9pm is my normal listening volume at night and I have 2 young children who are sleeping. The bass is very low and controlled. It will shake the house on some recordings if you play loud. I use no room treatment BUT did change SL speaker cables to Kudos and SL interconnect to HiLine as I found with SL the system was too bright for me. I am not a big fan of bright, fatiguing but HiFi sounds.
So maybe it’s a good news for Meni.
You convinced me guys
808s came for an extended test and stayed. Sublime speaker.
I see a number of people switched from SL2 to 606. Can they please try and describe the changes. Kudos loudspeakers are definitely accessible where I live and maybe consider them as an option to replace the SL2 in my place in Germany. Then I can ‘retire’ the SL2 to the house in France where i am sure they will shine. When I went to see my dealer I did see the 808 in the flesh and way over my budget and they are far too big. The 606 would be in a system that uses a CDS3 + 252 + 300, which to me sounds like a nicely balanced setup.
Hi - the 505/606 will run with a number of configurations from a Nova upwards but I suspect they will be optimised with a Nap 300.
I think the 300DR was the reference amp when developing the Titan range. So it’s a safe bet that the Titans sound great with a 300DR — unless of course the room is hopeless…
I am still very happy with my SBL mk1 with 52/SC/135?
My room is a bit of a non bass department - high ceiling, under the roof and sofa in mid of room.
So SBL has some bass problems but is very detailed on the other hand.
Would the 606 be a good choice or worth a try for olive Naim as well?
To be honest … thought about it for some time, but was hold back as my system seems well balanced. And my ears a a bit strangely calibrated - preferred the prefix over superline
Partnered with a 300DR, switching from SL2 to Titan 606 broughtin my small room … more…more of everything: more clarity, more punch, more details, larger soundstage, deeper bass etc… For me there is no way back.
From what you are saying, only trying a pair of 606 in your listening room could answer your question.
Thanks… will do so.
Do I need to pull the volume knob a bit more with kudos than with SBL.
Asking because on high volumes (which I never reach with SBL) I have a slight humming. Don’t want to stand this in the way of new spaeke4 audition.
As before testing will show :o)
