Hi
I have a Urika 1, Radikal LP12.
What’s the thoughts on the trampolin feet & the LP12 suspension acting together?
If you have a decent isolation platform do the Urika feet & Lp12 suspension give it too much sensitivity?
or the more sensitivty the better?
If not what is the alternative?
I have a Bloc rack which has glass surfaces.
The floor is wood glued to concrete so pretty solid.
Mark
Hi Mark,
I believe the consensus view is that the Tramp 2 is worthwhile on any surface even with a dedicated support. The original Tramp was very much for less than ideal placements like heavy furniture etc.
