Promotion started yesterday and running till 5th Jan, if you buy a new Select DSM whichever dac you choose will be upgraded to the next up for free. You pay for the cartridges required. I think I’ll be taking them up on this to replace my Akurate DSM beginning of Dec.
Nice offer but……. three auditions later, still not tempted
. Offer helps the trade ins a bit, but not grabbed by the Linn sound in the same way Naim grabs me and holds on.
Of course, YMMV and in a few years a one box solution might be the way.
ATB, J
I can understand that. My experience has been part of a whole system change and in my case the whole is better than the sum of its parts now. I have a much newer, better sounding system than before and absolutely no regrets. My only anxiety is whether a new Selekt/Utopik/Organik will be a big improvement over my ADSM/Utopik/Katalyst. Only a home dem will tell me although I think this will need to be over a few days to make sure.
Let us know how you get on!
I went in at a lower level and took advantage of the summer offer to go Majik DSM (replacing NAIT XS, BlueSound Node 2i, and a DV P75 Mk1 phono stage) and got a Karousel upgrade for my LP12, and haven’t been so happy with my system in ages.
That said, the Atom I compared with wasn’t far off, at the end of the day I had a slight preference for the Majik sound and a big preference for the app.
You have stated exactly the issue I had after i bought a Linn Selekt edition hub. Its cost me a fortune to get out of streaming and back to an amp and CD I liked.
Indeed, on checking some reviews, and we all know they’re utterly accurate, unbiased and correct - did I actually say that aloud
- the 200 Series and Titan 505’s were awarded ‘Best in Class’, whatever that means?
Then, whilst auditioning, the dealer kept pushing the better sound from the Edition/Organik variants and dithered a bit over quoting for the same configs in the Classic case suggesting the obvious that the additional £5k (for a case!!!) gave more margin to play with…..?
Everyone has to make a living, but……. kind of really, that much!
With that the whole auditioning experience became a bit meh
. Then I, pretty much by accident, listened to the Nova PE which removed any lingering doubts that the Selekt’s weren’t for me. If I ever want/need to move to a one-box solution, the PE, or perhaps its successor, will be high, if not top, on the list.
As ever YMMV, but there you go, and I haven’t really regretted the decision for a second, well, perhaps 2 or 3 secs
ATB, J
I’ve now owned both the Linn Selekt and the Nova PE. Despite waxing lyrical about the Selekt in the past, I must admit I’m not sure I’ve lost anything by moving to the Nova PE. It’s very, very impressive and a lot cheaper!
