Hi, this is my first post on the Naim Forum.
I’ve a question that I’ve not been able to find an answer for, and that is; is the connector on the tonearm end compatible with a Naim Aro which is, in turn, mounted on a Keel?
If not would it be possible to replace the connector on the T-Kable or the one on the Aro so they would be compatible.
My goal is to have balance connectors to be able to connect my cartridge to a phono preamble with balanced inputs.
As far as I know, the signal cables for the Linn and the Naim tonearms are different, and incompatible with each other.
Many years (thirty?) ago, I switched from a Linn Ittok to a Naim ARO tonearm, and the standard ARO signal cable was shorter than the signal cable for the Ittok which I had had previously. Because of the layout of my system, I needed a longer cable for the ARO and my dealer persuaded Naim to make a longer-than-standard cable. It was certainly never suggested that I should simply reuse the Ittok cable on the ARO, which would have been the quick and simple solution if the two had been compatible.
Hi Graham, don’t know if you’ve been ‘sprung’ yet, but that TKR waiting for you at home is the dogs wotsits in an ARO. It’s not just all the albums you’ve ordered - ALL your records will be new! Joy awaits!
Hang on a moment, KJC, I just need to check something very important. When you say that “Joy awaits”, do you mean the incredibly fit, nubile Ms Anya Taylor-Joy?
If she has indeed insinuated herself into my home, the Dynavector can go hang. If you don’t know the young lady, have a quick Google, and I think that you’ll see what I mean!
PS As to my release, thought of Ms Taylor-Joy drove all rational thought from my head, but a release date of tomorrow has been mooted, and a questionnaire has been handed to the internee. Chickens are not being counted, thouigh!
False dawn this morning. Will have to keep digging the tunnel, or maybe just break the lock on the window and struggle out. Not terribly keen on Police attendance, which was threatened last week. How can things get so silly, I wonder?
