Just rebuilding my classic system after decorating and I recall reading that certain locking should be left unlocked but I can’t remember which! Any help appreciated
Not that I have any, but I think I recall reading that some owners prefer to keep their Super Lumina cables unlocked
Its OK to leave the signal only IC locking rings loose
All others, the signal + power SNAIC cables should locked
And not to forget locking the burndys
Thank you
It’s a good idea to keep SNAICs collars locked to prevent nasty accidents. Interconnects though can have their collars undone and wound back.
The method I use is to insert and lock the connector first, then unlock the collar and slide collar back, then pull out the interconnect by about 1mm.
Does it make a difference? No idea to be honest, but some believe so, and no-one says worse, so a no brainer for me
I love recognizing a fellow adherent to my belief system At least in this case it’s free
