Logo illumination
Having returned from 2 weeks holiday, the Logo illumination on the perspex base of my Muso 2 is no longer working. How do I change the light bulb?
I would guess it’s an LED? And where are you, and is it under warranty
Martin
Did you unplug it or leave it plugged in when you went away? Have you tried unplugging, leaving of a few minutes and then plugging back in, or failing that, resetting the unit?
Check what the setting is in the app. From memory the logo can be off or on?
How many Naim forum members does it take to change a lightbulb?
672 - 1 to change the lightbulb and 671 to chip in and say that it was much easier to change the lightbulb in the Olive range and the Olive range was much better looking anyway :wink:
Thank you all you light bulb changers. There was me.wondering whether I would be thinking bayonet or E.S. I suspect there has been a software update in my absence because I found settings and the illumination had been switched off. Result.:smiling_face_with_sunglasses:
Reminds me of the “How many psychoanalysts does it take to change a lightbulb?”
Only one, but the lightbulb has to want to change.
