Hi to all, I have a Stageline. It a N version.However I had noticed that one of the rca connections has become loose and it clearly twists,whereas the other is as it should be (tight).Having seen the internals of these on another post I assume its merely a case of pinching up the nut on the back of the RCA.What is the best method of accessing the internals as I can only see 2 screws holding this item together.I certainly dont wish to get this stageline booked in gor a repair on something so simple.BTW the stageline works perfectly apart from this annoying feature.
If you remove the securing bolts from below you should then be able to slide the extruded cover off backwards.
All done,thank you!
