Looks like I spoke too soon @ChrisSU I closed the app, reopened it and they’d disappeared again. I logged out of Qobuz, then back in and they came back. Closed and then reopened the Naim app - gone again. Deleted and reloaded the app from the play store; favourites back. Closed and reopened app - gone.
There is no option that I can see to select whether Qobuz favourites are displayed or not. As far as I can remember, mine have always just been there.
Do you mean an update to Android itself, rather than the Android version of the Naim app? Whichever it is, a support request is a very good idea. I’ll see if I can add something in the beta group, once you confirm which it is. How frustrating.
I also have a Galaxy S22, and the new One UI was installed overnight.
However my Qobuz favourites are all present and correct on the home screen for each of my streamers.
Sorry (or happy?) to say I can’t replicate your issue. Have you tried rebooting your phone in case it still has some updating to do?
I just did a reboot but no change. I also tried logging out of Qobuz in the app, restart phone, log back in. Again, the favourites show…until I close and reopen the Naim app, whereupon they are gone. All other apps, as far as I can tell, are functioning as expected.
