Help ! I’ve lost all the artwork on my core. Is there anyway of getting this back ??
restart your router, then when restarted, restart your core then streamer. Should work Pmc1979.
Oui! As French Rooster says. It would probably be enough just to restart the Core actually.
Best
Turned everything off and on again - it worked ! Thanks very much both
