HNY everyone. Just wondered if any of those of you with turntables are still using this? I recall several years ago there were quite numerous reports of its use resulting in improved sound quality and it being recommended. I still have a bottle from back then and since settling my system back up have been considering using some on my beloved Kandid’s stylus. Did its use get debunked or linked to the premature death of styli or cantilever? Just thought I’d check first before trying it out.
Yep, I think Guinness is correct. The Kandid is made by Lyra and SPT is fine, just like the Akiva that preceded it. Wouldn’t use it on the newer EMT-made carts though without first checking with a Linn dealer and defo not the Krystal.
I’ve been using it for years and have been very happy with it. It’s especially effective when used with an Audio Technica AT-637 vibrating cleaner. It’s expensive, but a little goes a long way.
There are some cartridges you shouldn’t use it with - Linn Krystal is a well-known example - so check with the manufacturer first.
I have used LAST stylus cleaner with Dynavector cartridges for (maybe) 20 years. It does the job, and no cantilever problems, so I can happily recommend it.
It seems to be a bit cheaper than the SPT as well.
I use it before every side of an LP, followed by a quick ‘scrape’ with the magic green paper (see other thread).
I have used it with Dynavector DrT XV-1s without any problems. But always follow advice to wait 30 seconds after cleaning the stylus before playing a record. Never had any problems
A stylus is designed to vibrate, I can’t see why a few seconds of ultrasound would cause it stress compared to hours of vibration in the groove of a record.
Having checked the AT ART1000, I think its safe to say it has a totally different construction to most cartridges. Only the Decca London comes to mind as similarly ‘different’.
When I was using a Kandid I checked with Linn and they did clear the AT. Since most cartridge makers don’t have cleaners, I’d hope they’d have some advice for how to deal with their products.
Thanks guys. I’m using a combination of my original 80s AT vibrating pad and Onzow ZeroDust right now, which seem a pretty effective combination. Given that there aren’t any horror stories about the SPT, I’ll probably try some on the pad of the AT or use the brush that’s supplied with the fluid.
Appreciate the responses.
