Mains cables shootout on Naim full 500DR system including ND555, 2 x 555PSDRs and 552DR
Is there any update on River Snake Audio Takshaka mains power cables?
Just an update. I’m getting wonderful results with the Shunyata Alpha-X NR but it’s only good when used between the wall and power distributor feeding low-power components such as streamer, DAC, power supplies etc. Since I’m not particularly satisfied with the Alpha-X NR as it sounded rather poor with big amps, I’ve written to Shunyata. Long story short, they initially recommended either the Sigma-X XC or NR as a workable solution and after several exchanges the XC gets the final vote.
I already have sufficient mains power cables in my system and any additional (premium) cable will be an unnecessary lavish expenditure. Nevertheless, the Sigma-X XC is now in the bucket list. :grin:
A quick note. I have found that quick A/B comparison of mains power cables or any other cable does not work as the cable(s) need time to settle. I’m not sure about other cables but the Acrolink Mexcel power cables which I own require approximately 4-5 days to settle after they are inserted into the system. Shunyata advised to allow 2 to 3 days for the cables to settle before carrying out any serious listening.
I don’t blame you. The Sigma X (XC) is certainly very special. I’m still using it on all my Naim kit except for the amp, which is direct to the wall socket via a Powerline.
Just to check my findings I’ve gone back to using a Powerline with my Wireworld Matrix 2, a Music works G3 Ultra and Chord P3. I’ve done this on at least a couple of occasions, and whilst all of these combinations are very good the Sigma is truly on another level. The overall improvement, particularly on well recorded music, is just astonishing. Depth, width, dynamics, timing and tonal accuracy all take a massive jump. I’ve said it before, it’s like my 500 system takes a step closer towards a Statement system.
You mentioned that Shunyata suggests that their leads all need time to settle, and I would totally agree with this. If you move it expect at least a few hours before it comes back on song again. I also found this to be true with the Sigma ethernet cable.
If I was to try really hard to level some minor form of criticism at the Sigma X with Naim kit I would say that perhaps it’s almost too neutral and even-handed. Naim always carries that little midrange ‘bump’ and the Sigma can even this just a tad, especially when used with poorly recorded material. I guess what I’m saying isn’t so much of a criticism, it’s more about the extreme resolution of the Sigma cable has, and what it will reveal - warts and all!
Dan and I got an update the other day saying that the were almost ready for export, so we reckon maybe another couple of weeks?
At snake speed, around 5000 km from the States, 12 km/h , it should take 17 days, plus additional customs days.
@ryder I’ll echo @Geko ‘s comments as I’m using my X-XC in an almost identical way. I’d also add you may need to move your racks away from the wall a little to accommodate something that resembles a large conger eel in the room and avoid it touching other cables. I also found a slight adjustment to my speaker position and toe in improved things as the X-XC really does throw an enlarged soundstage. Enjoy!
:flexed_biceps:
I’m excited to hear your first impressions, after it arrives.
