FrenchRooster and I have been having a fun debate on and off about melco’s media library server products in a couple of threads. I have personally been in denial about the technology to improve the sound given I have already got a NAS and 24x7 server live and am tech literate, though he and others have heard differences. FR rightly points out I should also use my ears before pronouncing judgement. And he is quite right. And I definitely don’t want to deny what he or others are hearing. That would be wrong. So I have promised to listen.
Firstly let me say upfront for someone wanting an out of the box nas, server, ripper etc who doesn’t have the knowledge or inclination to replicate all this using separately bought technology I absolutely get it. Totally. However given I have already done all this, what is the basis for any potential sound improvement? I will always take improvements if they are reasonably priced, so I need to know where to prioritise this in the upgrade roadmap.
Rather than divert any more threads, I thought I would start a thread to guide me on what actually would be the basis for any improvement if/when I demo. I would like a clear hypothesis to test and guide me in more precise testing to reveal the maximum information for all. That would be a scientific approach - devise a series of tests that get to the bottom of what is the basis of the improvements in sound that people have heard.
The hypothesis I think would have to involve one or some combination of the following:
1. It has server software on it that bit streams music files to my streamer better than other software like twonky, asset, roon etc.
2. The nas features when providing file access to server software sound better than a traditional NAS like synology at a data level
3. It has a network switch capability that changes the noise profile of the network in the last leg as the lan connects to my streamer.
4. This network switch capability works to improve sound no matter where in my network I deploy it
5. The shielding of the pc components inside reduces the impact of noise on my hifi and network and that shielding is beneficial no matter where I deploy the device eg it works equally well when deployed to my study several rooms and switches away from my hifi.
Am I missing any hypotheses that could explain what is going on?
So I looked much more closely at the melco via its manual and a few reviews. It appears to be is a combined linux based NAS and single port network switch. Its seems to come bundled with twonky server and minim server which are both open source upnp servers. It has a control app bundled. It is not powerful enough to run roon or for that matter do any serious transcoding or dsp type processing as far as I can tell.
On one above I can see no special software that bit streams music to my NAS any differently to roon or asset. Can anyone else set me straight on this? So I will discount hypo 1 as being not relevant.
On hypo 2 - NAS features - if I were to deploy it next to my synology NAS, switch on the melco’s smb share to roon and a/b test it against my synology nas through my existing switches and ethernet cables I would be able to isolate if this capability of melco makes a difference. I am highly skeptical based on what I know of smb and nas technology but prepared to give it a go.
On 3/4 - the network switch - that is my most likely suspect for any improvement or change in sound. I know from my own testing that dedicated switches and different types of switch on the last leg change the character of the sound with my Linn DS. If people are using the melco as the last or second to last leg I can totally believe the whole device is acting like a giant EQ in their systems. Any changes to that setup in its position as last leg switch like new hard drives will likely change the noise shape. It’s also what one of the reviewers said that it was only when they used the network out from the melco into their streamer they heard benefits.
So how to test for this effect? Well I have options. I can put the melco in as the last switch and stream from roon sourced from my NAS and a/b against my last switch. If there are differences, its the network switch in the melco that is changing the sound.
I could also switch on wifi on my soon to be linn kdsm. The hypothesis would be that I can no longer hear any difference when i swap the melco in or out anywhere in my network compared to ethernet last leg from the melco.
Any other obvious tests?
On hypo 5 above - thats easy to test. I can install the melco in my office and simply a/b melco and its bundled twonky server against my nas and roon server. For the purposes of a test I would be prepared to power down the nas and server or at least pull out the network cables to my network. Forgive me if I do hear a difference here that I try to recreate the effect with twonky server installed on my own server and first raise a software defect against linn/roon’s RAAT implementation if I hear a difference again.
Have I missed any fundamental understanding of how melco works? When I get round to it I would like to make sure I test things thoroughly. And also prioritise doing all this against other beneficial upgrades.
All the best to all.
