I see in another thread that you traded your Mercedes for a Jaecoo.
I have an E class estate and I am thinking of swapping to something that is easier to get in and out of.
What do you think to your Jaecoo? Pros and cons?
Thank you.
Kind regards.
Roger
Hello Roger,
So far, I have no complaints—only positive impressions. It is new, though, so only time will tell how well it holds up in the long run. In terms of comfort, it’s excellent; overall, I think the price-to-quality ratio is good.
A mate who works in a well-known luxury car dealership (no names, no pack drill) says he went to test drive the latest Chinese (ahem) equivalents of the cars he sells and came away saying they were every bit as good inside and out, right down to the quality of the interior detailing. The only difference he could see is how much you’re prepared to pay for the brand name.
