Hi, I have a Uniti Core with both internal hdd and external ssd. I have an issue where I do not see all of the folders on the ssd when plugged into my Mac.
When plugged into the Core I see it as Uniti Core Ext\ Downloads with all of the 200 folders/files. However when plugged into the Mac directly I only see a fraction of the fees. Can anyone offer why this is ?
…because the “missing” files are located in the downloads folder on your internal disc maybe?
Just checked - you are correct !!
I was thunking that they were stored on the external USB. it’s been a long time since I set it up.
I have files on the external SSD they must simply be copies I have loaded manually.
thanks -
