Just curious why NAIM didn’t use an MLC SSD for their HDX upgrades? Given that the ultimate issue with MLC flash memory cells is the number of write/erase cycles, a server such as the HDX would primarily be writing once (or not many times) and mostly reading from each cell.
I realize that NAIM will never do this as their only solution to problems with the HDX is to replace the drives with either a 2TB mechanical drive or a 32gb SLC SSD (for the OS and control software only).
Just curious…
