Has anyone used Mogami 3082 with CB or Olive power amps. Is it safe or should I use it on a 250DR?
The specs say 253pF/m and inductance at 0.4µH/m so for 5m that is 1265 pF and 2 µH
FF
FF
Its not ideal, 5m with only 2uH is the problem, its well below the recommended 3.5uH
(3.5m) minimum. The C is a bit too high & that can also cause issues
Whatever its a coax & these are not ideal for connecting the Naim amps & conventional speakers and for this reason alone I would not go fot it even if L & C were OK.
The main problem is that the plugs stick out too far and prevent Naim speaker positioning. Worked with no other problems but they have to go back
FF
