Hello,
I have the following problem with my Mu-so generation 2: every time I try to turn it on from its remote or by tapping on the volume dial on the top of the unit, it starts the wake-up procedure as normal, so first the LED lights up orange, than fixed purple for a few seconds, and then as soon as the LED turns white after less than a second the unit turns off automatically. I’ve already tried to disable auto standby from the app, restarted my router, tried to connect the Mu-so via an ethernet cable, performed a factory reset, unplugged it from the mains and plugged it back in, but the same problem occurs: it always turns off automatically, no matter how many times I try to turn it on with its remote or by tapping on the volume dial.
Important note: if I turn it on via the phone app or via roon, it turns on perfectly without any of the aforementioned issues, although it always takes a while to fully wake up (about 30 seconds), to me it looks like it goes into deep sleep mode by default, although I set the auto standby mode to “never”.
Any assistance would be appreciated.
Thank you
Matt
