I know this product has had historical issues with radio streams dropping regularly. I have the same issue with some stations and not with others. Does the ability of the product to keep the stream rely on what type of stream is being used by the provider, or are they all the same (not in terms of stream/bit rate but “type”)? Is there any adjustment I can make to individual stations to make a particular stream more reliable? Thanks.
