Does anyone have a solution to this frustrating problem with the Multi-room function in my ND555 and Star used with the Core server. It doesn’t work. I am “certain” I’m following the directions (they’re not so complicated). All firmware is up to date. A potentially related problem occurs when I try to switch to the digital input on my Star for my Comcast TV audio signal. Often the only way I can get this to work is to re-boot the Star and the Comcast box. Re-booting doesn’t seem to solve the Multiple-room problem.
If you’ve experienced the same problem, and especially if you have a solution, you can skip the next paragraph and tell me how I fix it. Very happy to hear from anyone at Naim about this as well.
Here are the details. I choose a band from an album on the 555, start it playing in the room with the ND555. Then I click on the navigation bar to reveal the four dots square thingy, which I click on. Then I click the circle for the Star. The circle lights up. Problem is – the music never starts playing through the Star. And, yes, everything is unmuted.
Ideas?
