Muso has suddenly gone off and red led now flashing. I can reboot system and it works for about 5 mins then goes off and red led flashes. I’ve got the latest firmware installed. Can anyone offer any help or is it a return to manufacturer for repair ?
Neil
Normally , red is bad. (Sh*t … it rhymes… so it must be true)
I would contact the dealer.
AJK
May 28, 2020, 12:08pm
#3
Boingboing - Don’t panic yet.
Red and bad don’t really rhyme so you might be OK.
Panic already set in lol I think it’s got to go in for repair
One last try press and hold the reset butting for 5 mins …
it works some of the time when you see red
CBR600
May 28, 2020, 3:13pm
#7
I thought that the 1st Gen muso were not repairable?
Naim introduced a muso 1 repair scheme a few months ago.
Best
The 5 min reset has brought a few back to life.
Worth a try.
Normally when it’s a catastrophic failure you can smell it.
CBR600
May 28, 2020, 3:56pm
#11
That’s good to know. I have an original muso. No problems to date.
Tried holding the pinhole button in for 5 mins but again it worked for a few mins then the dreaded red flashing led again
Worth a try …that sucks but worth a try.
system
closed
July 27, 2020, 7:42pm
#15
