I have set up my new Muso 2nd Gen with an ethernet connection directly from my BT router. Everything works just fine, except Tidal Connect on the Naim app which will not play. I am able to log in to Tidal and select any album from their catalogue but nothing will play. Resetting the Muso on the wi-fi connection and Tidal works just fine. I prefer a wired connection, so any ideas as to what might be causing this problem with Tidal alone would be very helpful, thanks.
Sorted, thanks!
