Muso 2 Balance issue?
The balance on my Muso 2 seems to be louder on one side, right hand as you look at the Muso 2, quieter on the side of the rotary selector. Is this normal?
There’s no balance control on the muso.
I suggest to try stereo left right test tracks, do you have access to tidal or qobuz?
This is on qobuz
Thanks ill give it a whirl to check. I use Itunes so no balance adjustment. Definitely louder on the ‘left channel’, right hand side as you look at the Muso 2.
