We’re experiencing occassional drop outs on the MuSo Gen 2, it’s constantly on Radio 2 as that’s what my wife prefers! So I’ve not been able to check with Radio Paradise (RP) in the last few days. Drop outs happen just for a few seconds, then back OK, but it’ll come and go until I get fed up and switching to BBC Sounds and Airplaying to the MuSo, then no problems.
When my wife is out and I’m on RP all is well.
I’ve reset the MuSo, reset the router, got Internet Provider to check and they say all is well, speed is consistently good.
Extra info useful. Country, ISP? Muso firmware version number (latest isn’t a number)!
What is connected to your network? Any Sky Q box or IoT?
Time of day when drop outs occur; every day?
Which R2 feed?
Ahh, good points, apologies, as this is all a bit confusing… this is over wifi, and I’m in the UK, I’m naturally assumed everyone is in the UK ( ) ! ISP is PlusNet, no idea of firmware - how do I tell? No Sky or whatever IoT is, seems to happen both morning and afternoon, I’ve been using the HD Radio 2 channel.
Interestingly, whilst typing this I’ve had it on RP which has also just dropped for a few seconds
Ahh, found Firmware on phone, 4.3.2 (6482), it says it’s up to date.
Understandable, Naim is global brand, but it is necessary to give best info.
Ok, if on wifi, beg borrow or buy a patch cable. Plug into Muso and then to router. It’s a temporary arrangement, if nec order long patch cable.
Likely the plusnet wifi is creating an issue, which if you try the above, will progress trouble shooting.
How long have you had your Plusnet router?
Just to be clear, when the drop out occurs, nothing else is on your network?
four peps have tried to help - it takes but a mo to pop back, answer all ?s + update on progress ?
recent thread has highlighted - starting a thread and ignoring … ! Maybe take a read; part of the community spirit.
Thank you for the reminder, patience is a virtue. Advice and support appreciated… Between then and now… I’ve been away for a few days camping without access to any signal, father taken into hospital very ill and I now part way through Covid recovery. Hopefully that’s reason enough, but yes, point taken.
I swithched router off and reset wifi to use the 5ghz band (had been on 2.4), then reset MuSo using a cutting edge pink paper clip, after what seemed an eternity it came back to life and not dropped since*. I think probably the reset may have been the key, not done in the last 12 months+, I guess stream is still new and every now and then it’ll need a restart.
wife tells me it’s fine as I’ve been banished to a bedroom to recover with juust a B&O S3 for company
Note - written whilst I still have a temperature, so treat as such
