Hi, I’ve owned my Muso 2 for nearly a year, and during this time, I’ve had no problem downloading and saving radio stations via my home wi-fi, using the Radio option on the Muso 2.
However, recently I’m unable to see the list of available radio stations, unless I use the search function, and even then I’m unable to play various stations.
The connection to my router is ok, as I can save and play a couple of radio stations.
I can also listen to internet radio stations from my iPad using AirPlay.
Has anyone else experienced a similar problem, and found a solution?
Hi. I am getting the same problem with both a Muso and Unity Star which started over the last couple of days. I see that there was a post about a similar problem with Streaming BBC Internet radio services that occurred in August/September of this year which was down to a BBC upgrade with their services. Perhaps Naim can check if this is a similar problem with the BBC please?
