I have the update symbol showing in the app for the musu qb2 but the firmware offered is 4.2.0 whereas I’m running 4.2.2
Hi @Yeti
We believe this is because you are part of the beta test program and the app has an old beta certificate installed.
If you need help on this, ping us a message in the private beta forum area.
Best wishes
Steve Harris
Software Director
Naim Audio Ltd.
It might be connected but my update is set to release version and has been since buying the qb a week ago.
It’s gone away again now.
Hi @Yeti
We tracked the problem down. Our backup upgrade server had an older firmware image on. For some reason the primary Amazon S3 hosted one could not be contacted from your network and it fell back to the non Amazon alternative.
Thanks for the report - made us think a bit on what was going on.
Steve Harris
Software Director
Naim Audio Ltd.
