Hey there, I had a question about my Muso, I use the cube as the sound for a television in my kitchen but using the optical input I get a tremendous amount of feedback out of the unit. Has anyone else had this problem?
Thank you, Brian
Thank you, Brian
Is the optical out on the TV set to 2.0 PCM ?
When you say “feedback” what exactly are you experiencing here?
