Muso qb 2 & Airplay 2
Recently I use airplay from my qb2, but it stops playing music after connecting to airplay.
Then I use Spotify connect, and it works for a long time.
So, what happened to airplay?
I use android Motorola Edge/naim app/tidal; quboz; chromecast and win 10 pc casting to my muso 2nd gen…all are rock solid. Is this an airplay issue?
I use AirPlay with my Naim gear and it always works fine. This sounds like a network issue so try rebooting your router and check Wi-Fi for local congestion and signal strength.
It could also be you are running two network devices in router mode, so are suffering from double NAT, which causes all sorts of weird issues!
