Agree, I guess as it gets cheaper to buy an atom or classic series on the used market then the trickle down of reduced prices for Muso’s probably follows suit.
Was replying to @Pietr.
Roger
Ok, I did a listening session with the Kef LS50 Wireless II. It’s a good kit, liked them but would not fit the need for my studio room. At low volume levels, they are thin and whispering - need some power to showcase capabilities, and it’s not for my use-case. The rear firing reflex port is another drawback, as would do his magic only at some distance from the wall - eating room space.
Paired with a sub they do shine - but would be exceeding my budget - and I can see how a bit of pairing work with separate Amp + LS50 Meta (non amplified flavor) can have same cost and possibly better sound as well, but for the short time being I’m keeping my MuSo 2. The more I compare it with alternatives, the more I find that for the location it is and the function it has to deliver, it’s a perfect fit.
Change for the sake of change not my style.
