Jaybar: alright - I dug the Focal Clear out of their nice protective case and wired to use a 6.3mm output (1/4 inch jack); it was 2am and I wasn’t sleeping, guilty I’d promised to do this check and hadn’t done anything to ‘prepare’.
My Clears hadn’t been fired up for around six months, and I’d never actually bothered to finish breaking them in when I realised their sound profile simply wasn’t for me…
At two thirty AM, having Nine Inch Nails “Into the Void” set to play on repeat (at 8:15am on the Nait volume pot), I briefly put the Clear on my head/over my ears…
The music I heard sounded really really good (in a way that no portable amp I have ever used has ‘sounded this good’)…
I went to bed (again) knowing that the Focal/Naim pairing is a really good one…
Whilst I had only listened for less than half a minute, the bass tautness, the staging and the easy to pick out depth rendering of ‘instruments’ (remember: “Nine Inch Nails”), was excellent.
The only weakness was the size of the soundfield… to my ears, the Clear do not perform like any other ‘open backs’ I have heard… they have always had a soundfield size equal to better closed backs, but, a hybrid like the Sony MDRZ7 outclasses them for staging… (and bass).
As for the Naim amp?
Brilliant…
I look forward to running a few test tracks via a Burson Conductor V2/Audio Gd R28/Nait XS3 (as headphone amps)…
If the Nait XS3 doesn’t hold its own against the big dogs, I will scale down the ancillories and compare to the iFi Diablo, and some other ‘more budget’ deskamps… etc…
Most critically - what music do you listen to (genre’s?)
As an example, I have a DAP (digital audio player) that has 4x Sabre DAC chips AND a valve stage, and allows ‘switching’ on the fly easily…
It becomes clear to see that different amp topologies work best with ‘certain genres’ of music, and my experience with many (many) headphone amps over the decades would confirm that ‘beyond volume’ most headamps would be chosen for the GENRES that they are optimised to do best…
The sleepy/relaxed bass note from the valve preamp: nice for jazz, but not ideal for high beats per minute electronica (the quad DAC/no tube output would do that genre better)…
I will listen to the genres you prefer via the Naim kit and check for the matchup…
To be fair - orchestral music is some of the hardest to reproduce- requires dynamic swings, incredible signal to noise ratio, accurate LAYERED positioning and timing, timing, timing…
There isn’t always a lot to sort the wheat from the chaff, so to speak, when listening to ‘easier to drive’ genres…
That being said- Rock can require rendering phase shifting guitars etc,… and so - can a given amp play back the genre you seek is the REAL QUESTION…
From what I heard, briefly, this morning; the Nait included headamps are ‘the real deal’ and not shabby.
Again- I use mine weekly when I have two ‘better’ (technically) headamps on desk that require no effort to use…
Majority of the home amplifiers I have ever seen have headphone socket as an afterthought/bulletpoint, and the internal wiring shows THAT…
The Naits ARE very decent headphone amps, certainly VS the majority of consumer fi that floods the market…
Hence why I will bench the Naits’ internal headamp vs ‘really good desktop seperates’.
TL : DR (too long; didn’t read)?
please share with me your five favourite recordings to listen to (/genre preferences).
Cheers/ Thanks in advance.
