My NAIM remote has gone crazy
Hi there, if someone could help me with this, I’d be thrilled.
I have a NAIM amplifier and cd player. The cd player’s remote’s has gone awry last week. The only functional buttons are play, volume level arrows, mute, pause, stop, next and previous. The display, the numbered keys as well as the previous and next arrows are dead. Is there some kind of reset recipe ? My instructions booklet is long gone… Thanks !!
Do you know which remote you have?
The first thing to do whenever you experience odd behaviour with the remote handset is to remove the old batteries and then try new ones, as strange things can occur as the voltage drops.
Thanks Richard. Switching to new batteries is the first thing I did when the problem arose. It didn’t change anything. I also tried the second remote I have (it came with two when I purchased the machines). I guess it’s some kind of programming thing ?
My remote only has ‘NAIM’ on front and ‘CE’ on the back. No model or number anywhere to be seen. The cd player is CD 5 i and the amp is a NAIM, model NAit5i
Post a picture… so it can be ID’ed…?
It sounds like it might be the dreaded little i-Com remote handset that came with the 5i kit. Not unusual for them to eventually break or stop working by now. Better to get a proper NARCOM remote which should be far more reliable.
Like this?
My n-SUB remote has done more or less the same. It is quite common for these old i-Com hand remote controls to fail. I’ve had three of them over the years and all have eventually fizzled out.
In your case a replacement NARCOM 5 would be ideal.
Mine is different. I didn’t know we could put a pic.
Tell me if the image shows correctly.
Ah, OK a NARCOM 4 (or known internally as a “stealth” handset). Have you tried taking it apart to give it a clean?
Don’t forget that you need to press the cd button to get all of the functionality to operate the cd player. Similarly you press pre to get everything for the amplifier.
Yes indeed. As HH advises, you may just need a firmer press on the CD softkey which tells the handset to assign to the buttons for CD function.
I’ll give it a cleaning but I doubt it’ll help since both remotes have the exact same malfunction.
Next step, I guess. I’ll try that later today (going to work). Thanks !
IT WORKED !!!
Thank you so much guys !! I did just that and everything is back to normal.
I suspect my grandchildren have used the remotes as light sabers again … :robot:
Excellent. We’ve all been there.
