My ND5 XS 2 has suddenly started going into standby mode
My ND5 XS 2 has suddenly started going into Standby Mode, after about 30 minutes of being turned on. Up until now, it was permanently on without going into Standby Mode. Any thoughts or suggestions?
Doubt it’s anything that can be cured here. Sounds like a hardware fault.
Suggest you contact your/ a dealer and take advice there.
Have you made any changes - Auto Standby time, turned off server mode etc.
What does the app show ? Go to Settings (gear icon) > Other Settings
Thanks, James.
Following your suggestion, I checked the app and yes, it seems following a short power outage, that the unit reset itself, and in so doing must have initiated the Auto Standby for 20 minutes.
I have now resolved it and it is back to ‘Never’.
At the time of my question, I was unaware of there being a Auto Standby setting, as the unit was permanently on since I first bought it and plugged it in.
A new world has opened up when I access my app now!
Thanks again.
Thanks, Neil.
All was simply resolved - see my reply to James below.
That’s good news. Glad to hear it was an easy fix.
Ahh..perfect. glad you got it sorted.
Every day is a school day.. as they say.
