Hi there, there was a big earthquake in Panama yesterday. Fortunately all is well and not many damages in Panama City. But, after the earthquake my NDS stopped working from the SPDIF inputs. I get a “not signal” indication. It works through the ethernet connection using Naim app though. What could be the problem?
Have you tried remaking all the connections and doing a hard re-boot?
Otherwise, I would guess perhaps a connector has come loose or broken, or perhaps the quake created a dry solder joint? @NeilS might have further ideas here.
The digital inputs are on a sub PCB connected via a flat-flex ribbon to the DSP/DAC PCB - might be worth checking nothing has been disturbed during the earthquake.
Neil.
Very pleased that you are OK & that there was little damage caused by the quake.
That said, your subject heading must go down as a forum classic.
It could only be topped by “My NDS stopped working after the nuclear explosion…….”
I hope I am not being too flipent in the circumstances.
Many thanks, that is my intuition also. With the violent shake an internal connection is broken. I will open and check.
Well… that was the problem. After reconnecting it is working fine. Many thanks ![]()
Maybe the floating design worked similar to the wind damper in the top of Taipei 101 preventing further damage
(been there)
I just did the consultation with Grok SI. Here it is: a magnitude 8 earthquake is energetically in the same ballpark as the biggest thermonuclear tests ever conducted, or about a thousand Hiroshima-sized bombs.
So, you are correct, they are equivalent circunstances!
