Can you use Apple airplay on 1st gen my-so ? I just get can’t connect message. Firmware 1.8.0 installed. I don’t want to subscribe to Apple Music if I can’t stream to mu-so
I can stream from my iTunes library to gen 1 Muso. Oddly enough I never see Airplay mention though, if you play something from your iTunes library and connect by the red icon (middle) at the bottom of your Apple device.
Thx for that. I wanted to use Apple Music app to stream but can’t get it to connect
Im sure someone with more technical knowledge than me will come to your aid. Good luck.
The 1st generation Mu-So and Mu-So Qb support AirPlay 2. I have a Qb and can use AirPlay from any of my Apple devices without issue. If the firmware is up to date on the Mu-So and your devices are connected to the same network (not on a separate sub-net) then you have a router or network issue. Update the firmware in your router and ensure your Apple device really is connected to the same network as the Mu-So.
Once you’ve checked all that (see XMB’s post above) then try re-booting the router and all your devices then try again.
Hi I’ve tried it all and it still won’t connect. Spotify connects perfectly and radio channels working fine. I really don’t understand as I’ve got everything connected to the same network and all software is upto date
It certainly should work - I use Airplay regularly on the Mu-So. Does the Mu-So just not show up as an Airplay speaker for you to use?
It shows up as a speaker but I just get the message air play cannot connect. I did wonder if it’s because I’m not subscribed to Apple Music yet. I’ve just let my Spotify premium lapse and just noticed that if I try Spotify the muso is greyed out and says premium only underneath ?
Don’t want to switch to Apple Music and find I can’t connect the muso
OK, the fact that it shows up as a speaker is good news. That means it’s connecting OK and, all else being well, should work, however I can’t be sure as I don’t use Apple Music, just iTunes. I would suggest asking Apple.
Cheers Richard
I use first gen Mu-so via Airplay in Roon all the time, no apple music software in sight (other than the iPad or MacBook OS) . Has to be a network issue.
Thanks all. Finally resolved. Rebooted speaker and it now airplay’s. So weird that everything else was working except airplay.
