Well. He did post this.
May be some advice from experience on how best to make 272 work (on Wifi)?
Thanks HH, I think I found how to rediscover my 272 in the app.
Basically you desactivate and reactivate DHCP on the 272, let it réinitialise and make sure your app is on the main WiFi router provided by your internet service provider, no matter if your 272 is connected via Ethernet cable to your mesh WiFi network (like in my case).
Same issues here since updating to 4.8.
As suggested it might be a network related thing. Changing te networks settings off an on DHCP did the trick for me for a while but seems not to work anymore. It is getting annoying and to be honest putting me off listening to music as I have to manually switch every time from dhcp to no dhcp. And switching the router off. Also it shouldnât be necessary!
No software updates on the router (Netgear nighthawk r7800).
It is a bit strange that since updating de NAC software problems started. Is the way the 272 connects to the internet changed in te program/software?
