NA523S match with LYRA mc
Hello,
can someone please, tell me if NA523S phono boards are good match with LYRA Dorian and Delos mc cartridges? Both are 0.6 mV of voltage output. Will it work well with NA523S or output voltage is too high and I need different boards? They would be used with Nac82/Nap180/Linn Sondek 12 with Akito or Technics 1210 mkll with original tonearm. Thanks in advance!
I’ve had both of them not a good match for Naim 523 S or K boards,too high output.
Maybe you can use a set of boards for MM and get a SUT that is matched for the output.
