They are all good, so long as serviced. Personal view is that the early ones with 2 sets of bnc inputs are more usefull. Albeit if they ( imo) are changed to RCA.
Allows a line input for a streamer and an input from an external phono stage.
Or, you can use two internal phono stages via cards. MM and MC.
The key is getting them off to Darran for a service. Plenty of options to have the bncs swapped for rcas.
And remove the near useless 328 cards and have the links remade.
Yeah, find one thatâs been serviced or expect to get it serviced if it hasnât. The later ones have the CD input iirc. 72/HC/250 is a legendary set up and can be had for relatively cheap now.
All 72âs are good. As @Thegreatroberto has said, the earlier ones came with 2 sets of BNC inputs, which were usually fitted with Phono Boards (322N, 323S or 323K) and the 328 âVâ Variable line input boards. Later units had just one set of BNCâs for Phono (again with N,S or K boards), with the other set replaced by a line input now marked as CD (previously was Aux).
I originally had the earlier one - now I have the later one. Both are good.
Agreed, except that there are many old, unserviced or unofficially modified units out there, so you can never be entirely sure what you are going to get.
Relatively yes. Cheap, no. These three are all serviced. Top 2 in Sheffield, the 250 in Salisbury. Fed from a Node, then to little dali speakers via naca5.
Those three boxes would be costing someone close to ÂŁ3k if they wanted them off me. And no, they are not for sale. Took me a while to find three boxes this mint
Seems pretty cheap to me.
Would that include the aeroplane ?
Just askinâ
Not entirely true I see a 82 at a dealer well known for their pre-loved naim stuff.
82 is more âgrown upâ than 72 and also has a remote which the 72 lacksâŚ
There is one on another hifi site.
Yeh, but the 72 is cuter ![]()
Can you share where you e seen this ?
Pink Fish yesterday at 4:39 pm.
I saw the one I mentioned on the audio site that reminds me of what was once the brand for sat navs (canât post links due to forum rules).
drumsâŚ
Snare snare audio? ![]()
Thanks for this - I picked it up on Monday!
Hopefully a good un. Enjoy.
