With my 252 I made a connection from Rec to a BeyerDynamic A20 headphone amp to power my ZMF Verité headphones.
Impedance: 300 Ohms
Sensitivity: ~97dB/mW
That worked very well and I was also very happy the 252 could do two output jobs at the same time.
In came the 332 with integrated headphone out and only one set of outputs to choose from and 1.5w into 16Ω.
Two questions:
1 - will the 332 suffice for my headphones? Or do I keep my A20 amp hooked up.
2 - If I keep the A20, how to connect it to the 332? I thought it would be a simple matter of interlinks in the RCA outputs of the 332. But then I get no sound. Is there a programming sequence I am missing or am I connecting it wrong?
Tried it, seems to take a lot of amplification for my cans. But still hard to compare the sound as I don’t know how to connect my old method.
on off switch, wow, didn’t notice that, thank you.
Just read up on that, it is to be used for “older” style amps, or subwoofers. Old (252) style Rec out is unavailable, so my guess now is that what I want to test is impossible.
The question is also for the technically apt, as I am not, to what would be ideal, looking at the numbers and what it would bring to the sound quality.
You need to connect the headphone amp to the input 8 5-pin DIN, which has line level outputs.
Amazingly, it’s all in the manual, which I’ve just read online and is how I now know what you should do. Hopefully the cable you used with the 252 will work happily.
You don’t want to use the output RCAs as they are post volume control and you’ll only be able to mute the speakers by turning off the power amp/s.
Input 6 (8 pin DIN) is compatible with 5 pin DIN leads and can also directly power a Naim
NVC TT phono stage.
Input 8 (5 pin DIN) has line level outputs mirroring the currently selected source. Note that
when this input is selected the source connected will be mirrored, so beware of feedback
loops if using a recording source.
Thank you @HungryHalibut . This works very well. Perhaps @Richard.Dane can add this “input 8” part to the faq concerning connecting 3rd party headphone amps.
A short addition to this for whom it may be useful:
I received a support message from my headphones manufacturer that the 16 Ω of the 332 is certainly a high enough OHM out that it won’t affect the sound negatively.
I found out that the volume level trim setting on the 332 dial can also be adjusted if you plug in the headphones. The manual was not too clear on that for me.
I am now going to do a few days with both options trying to decide what I prefer. My first thought is that the class A BeyerDynamic runs the cans with more ease, but this might not be more important than the possibility of lower box count.
Yes I like that it also remembers the volume you last used for headphones, when you plug them in you see the LED move smoothly round to the level, nice
Having a good headphone amp built in was another plus point for me, had really missed that with the 282.
