I have a nac 62 with 323 phono boards. I have just fitted a dynavector low output moving coil cartridge (DV-20X2L). Do I need to change the boards?
No, if they’re the standard NA323S boards they’re ideal for a low output Dynavector MC.
323 K boards would also work, I would guess…?
They’ll work Ok yes, but S boards have traditionally sounded better with Dynavector Low output MCs.
I was just thinking that S or K boards are the most likely ones the OP will have…
