Hello all,
Can anyone tell me which Naim remote controls will work with a Nac82?
The reason for the question is I’m considering buying an 82 which doesn’t have a working remote and I’m hoping to source an alternative.
Thanks.
Pretty much any Narcom should be fine. You can also use a Flash, R-com or i-com.
My CDX2 remote has no problem controlling my 82…
Thank you guys, that’s helpful.
I think Narcom 2 or 3 was relevant to the 82. There is a Narcom 5 for sale at a hefty £79.00!
The seller didn’t think it would operate an 82.
The Narcom 5 works an 82 just fine.
Yup, a Narcom 5 will work just fine.
