What combination is best soundwise, NAC N172XS+NAP200 or Supernait1+ND5XS?
Let me known.
Let me known.
I had the oppertunity to compare a Nait XS2+ND5XS to my Superuniti this weekend.
Set up:
Neat Motive SX2 connected with 2x3.5 m NACA5
Mofi Studiodeck+
Rega Fono mm MK3 connected with rca-din cable
Audiolab 6000 CDT connected with coax
Spotify 320 kbs
Nait xs2+ND5xs:
Pro’s:
Full earthy SQ, lively, bolt, robust, fleshed out
Cons:
Sound gets congested at higher volumes especially with female voices
Sound refuses to open up and sprakle and therefor has no fit, sit and forget qualities
Sounds a bit warmish
Superuniti:
Pro’s: open, lively and sprakly with good bass, one box, channel balance correction, fit, sit and forget qualities
Con’s: not as fleshed out as Nait XS2+ND5xs
So stick with the SU.
