Quick question … misplaced my remote and was wondering if I set up system automation on the nds would it turn of the display on the 252 as primarily that’s what I used it for
System automation only operates the volume. You need the pre-remote to switch off the 252 display I’m afraid.
And input, just to be complete
Thanks gents appreciate the reply’s , onward to find a narcom then …
