Hi. I am currently running a 32.5 hicap with CB 135s and a ND5 xs2. I found a NAC 272 with XPS dr for a good price and was wondering if you all think this is a good decision or more of a lateral move regarding sound quality? I was looking for a 52/sc but failed in my search. Would I be better off waiting to find the 52/sc or move on the 272/xps. Thank you for all input.
Welcome,
My answer is in the shape of a couple of questions;
What do you really really want?
If it’s the 52/sc then will the alternative scratch that itch?
Over the last 12 months I have looked at umpteen TT’s but kept coming back to Linn’s LP12, other decks were good, some were very very good but every time I saw a LP12………
If you bought a 272/XPS and then saw the advert for the 52/sc how would you feel?
If you want the 52 then be patient, one will come along in due course.
The 272 is a generation behind the ND5XS2’s streaming board.
I’d hang on for the 52 and then look to the source, perhaps adding a pre loved Naim DAC and using the ND5XS2 as the digital source.
Thank you for the reply’s. Part of my issue is I have no frame of reference and without hearing them for myself I’m going by what I’ve read. I am thinking there a very few 52/sc around because people hold onto them and that they are really good. I am leaning towards being patient and holding out for the 52/sc. I think this set up with the streamer will deliver zero complaints.
If you don’t need the streaming feature from N272, I’d not expect it to better a fresh serviced 32.5, it will be different indeed.
Then there’s the display issue with 272 to consider.
If you want a 52/SC then wait, its very very good and comes up now and then.
Sticking with the current set-up and waiting for a 52/SC would be my advice.
Thanks to all. I’m on the hunt
They do come up, but try to make sure it has been serviced and if possible upgraded to the POTS8 version.
A good 52 is a very goid thing, and has a style and character that the newer kit do not have. It will surely suit your existing stuff better.
Bruce
