I had, many years ago now, a sheet with different labels for the input selector buttons of the NAC52.
I can’t find it any more and I wonder if I would I be able to get hold of such a sheet of labels now, and - if so - where I could do so?
You could try your Naim dealer - they may have some stashed at the back of a drawer, otherwise keep your eyes peeled on the usual places like ebay etc… where they often appear.
Expect to pay around forty quid on eBay.
I am very careful and very sensitive with my naims, but have no problem when using CD for streamer and tuner for phono
Huh?
I’m not sure either.
Exactly. So long as you remember which is which, you are fine.
I suppose this is an issue only for the wonderful Olives. Lesser preamps need not apply.
Why not use Phono for Phono and Aux for Streamer?
Input 3 - Tuner is the best input option in regard to SQ. Read it several time and tested it
You can put different labels on, assuming you have some of course.
Input 3 on mine is ‘CD’.
What is a good search term for it? “Naim labels” returns all sorts of recordings.
Search for Naim and order by lowest price first.
That’s sounds the best idea. Probably the only less costly part sporting a Naim logo is a CD puck!
Have you actually tried that? You may be surprised by how many clone amplifier modules there are out there.
Add a filter to do UK only. The fakes/clones get kicked off eventually.
Pity they didn’t have the foresight to have a “Streamer” label I 1990
Or even a label for “dac”. For my nDAC input, I use “dcc” - whatever that means………
Digital Compact Cassette. I may be wrong.
