If you search DIN -RCA on the forum, there are a number of threads on this, including pin diagrams.
Edited to correct
The picture shows the “as viewed from the back” faces of the male (cable mounted) & female (chassis mounted) connectors, so one will be “reversed” wrt the other. Print it out then fold the paper down the middle…….
Pin 1 connects to pin 1, 2 to 2, etc
I know that.
Looking at Wikipedia, the the diagram I’ve posted is wrong. The male should be shown as female and Vice versa.
Yes, you are correct.
And the lavender that I have just taken apart has the signals on pins 3 & 5 (as per the numbers printed into the connectors front face)……and at both ends…
I would just like to add that dismantling cables while balancing a sleeping cat on one’s lap is a tad challenging……
Buy DIN to 4 RCA plugs…plug 2 of the RCA s into the headphone amp till it works on both channels then be done with it.
Yes the FAQ Richard posted way back up explains it all nicely, but here we are at 48 posts…
Just ask questions - never look anything up. Seems to be the way things just ‘are’, these days.
Oops sorry ! Understood
Will do Thanks Neil
Best to ignore everything I said.
The pin details I was looking at where incorrect.
Too late
Best to get a Naim dealer to make up the right cable, or a manufacturer who knows the Naim wiring, e.g. Witchhat or Audio Sensibility and be very specific about what you are connecting to what. I recently had my dealer make up a cable to connect the 552 to a Heed Canalot headphone amp - works very well.
