Just spotted 2 7m-lengths of Linn K20, going very cheap. If I’m not mistaken, the Linn K20 is the same as Naca4? Is the sound very different?
This might be a good introduction to Naim speaker cable, which I’ve never tried.
Thank you for your replies!
Identical other than the stamping, made on the same line.
Go for it.
Any comments about the sound? Are they similar to Naca5?
In an olive or later Naim system, I’d say A5 is “better” - somewhat clearer/more tuneful than A4/K20; though some may say A5 is “brighter.” In a different system you’d have to try it. In my system, A5 is ever so slightly better, but I use a biwire set of K20 because it’s so much more flexible.
I would not say it is a dramatic difference, so if the K20 is still available for very cheap just get it.
Thanks!
