NACA5 gauge / MM size
Anyone know the size of NACA5 - in either AWG or sq MM? I’ve done some lookups on Google and there seems to be some variation between 11 and 14 AWG, but consensus that it’s approx. 4 sq MM? Im trying to fit a set of non-NACA5 cables for something else and trying to use this size as a reference. If anyone has the definitive answer (in either AWG or MM) would be much appreciated!!
It’s 4mm square which is approximately 11 AWG.
Thanks! That seems about right. I’m going to DIY a 2m pair of cables, so 11/12 gauge seems to match up.
Your profile shows your’re located in Germany, so why are you asking questions about AWG ???
Naim www only show mm/2, NACA5 is 4mm/2
Inquiring minds want to know? :grinning_face:
