Hi
I left a comment within the “New app” topic but due to its vast number of entries, difficult to see if anyone commented, therefore starting a new topic.
Could someone answer the following questions associated with the Naim app and its use on a tablet using Android 5.1.
Previous to the “New” app October 2022, I used the above device without any major issues and sometimes re installed the app from the Play Store when the app was sluggish.
App “reset” rather than complete re-install has been the way forward, since recent advice.
The tablet currently has Naim App version 2.24.0 and working.
Since the new app has been issued, it does not appear within my “Play Store” and only retrievable through Google search. As this new Focal/Naim app is designed for Android 6.0, I assume this is why it’s not searchable within my “Play Store”.
I should have qualified a little - the tablet is used primarily for the Core and not much else.
QUESTIONS
- I assume, in the event of MY app requiring a reinstall or for that matter an app “reset” -
I will not be able to carry out either operation and will be without an app to operate the Core. - Is there an alternative to having to purchase a new tablet to operate the Naim Core?
Many Thanks
